Voltage draining
Discussion in 'International Forum' started by onecurlyalex, Jun 5, 2015.
  1. onecurlyalex
    onecurlyalex Bobtail Member
    17
    Newbie here. 2010 Prostar. The problem began at a rest area, I tried to start the truck and it wouldn't turn over. The voltage was over 13. I asked around, and some helped with hitting the starter a couple times with a hammer.
    Before this, I smelled a burning oil/electrical odor for quite some time, one and off, didn't think anything off it, cause this truck is sketchy rigged all the time.
    So after the rest area incident, was driving and not paying attention the the volt meter, I hear the warning signal and my volts are at 12.
    Long story short, been driving for 2000 miles with the volts fluctuating, and getting drained ### soon as it charges up some. Replaced the alternator, replaced a burned wire from the ignition switch to the starter, been to 3 different shops, checking 4 different times and no one can find the problem. When it sits, the alternator puts out normal volts, and the batteries show normal too.
    Something somewhere is draining the power, but can't figure out what. Maybe a short somewhere or something? Need help, 2500 miles left to get home.
  3. kw600
    kw600 Road Train Member
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Did you check for loose connections?
  4. onecurlyalex
    17
    There were a couple loose connections on the starter, but they were tightened up at the first shop, problem still there.
  5. kw600
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    So you know the screwdriver trick in case you have to turn off the truck and it won't turn back on?
  6. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    CK. the ground wires that run along with pos. wires to your starter. + ground from alt. to frame if it has one?
  7. onecurlyalex
    17
    Yes, but it starts now with one try after the wire was replaced. It just doesn't charge up to 14V anymore. When it does charge up, randomly, it doesn't go past 13.3ish. Then it gradually drops back down. I have to stop so it doesn't go into load shedding.
  8. onecurlyalex
    17
    What am I checking for?
  9. roadglide547
    roadglide547 Bobtail Member
    8
    Corrosion, new trucks worst enemy, clean all electrical connections especially battery's
  10. SCtruckerdude
    SCtruckerdude Bobtail Member
    45
    38
    Oct 17, 2013
    Yeah that's the solution. If it doesn't work beat it with a hammer. LOL
  11. onecurlyalex
    17
    New revelation. I did an air leakage test, and that drained my volts. Talked to a guy, he's saying it could be a bad brake module? That would explain the rise and drop when I'm driving.
