Voltage Drop
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 97Peter379, Apr 7, 2023.
  1. 97Peter379
    97Peter379 Bobtail Member
    Apr 7, 2023
    Hey guys,
    I have a 97 Pete 379 experiencing a 1v voltage drop in sync with the right turn signal. Blower motor, marker lights, headlights, brake lights also cause smaller drop in voltage.
    With the right turn signal on, the voltage drops in sync with it for about 10 seconds before clicking and no longer working. After about 10 seconds it clicks back on & will work for a shorter amount of time.
    left turn signal works perfectly and has zero drop in voltage. Any help would be appreciated! Thanks!
  3. Big Road Skateboard
    6,795
    38,274
    May 2, 2021
    And battery cable/battery condition is?
    Diesel Dave Thanks this.
  4. Diesel Dave
    9,386
    30,505
    Jan 20, 2010
    Hesperia, Ca.
    I had a loose cable on back of the alternator. It would drop the volt meter if I turned anything on. At first I thought it was the batteries going bad but all the cables were good as the batteries. I couldn’t figure it out until I figured the alternator was shot. So I check it and that’s when I found the loose cable.
  5. bad-luck
    bad-luck Road Train Member
    3,384
    6,263
    Nov 16, 2013
    Baltimore, Maryland
    I am thinking that a hot wire to one of these is grounding out. Could possibly be in on of the running lights, maybe in the turn signal.
  6. 97Peter379
    Apr 7, 2023
    Some battery cables were corroded on both positive and negative sides . Replaced and all is well again. Turns out something that seems really complex can have a simple solution ‍ thanks for your help
  7. Big Road Skateboard
    6,795
    38,274
    May 2, 2021
    Glad you got it figured out.
    97Peter379 Thanks this.
