Voltmeter reading low, alternator and batts good
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gumper, Mar 22, 2018.
  1. Gumper
    Gumper Road Train Member
    1,579
    3,845
    Jan 7, 2018
    Butte, MT
    So now my next headache. My voltmeter is reading 12v, down to 11v with all the lights on and heater running. The batteries and alternator are running 14v though. All the lights are bright, and when I turn all the accessories off it creeps back up to 12v on the gauge. I drove it around while to see if the batteries were draining, and it seems fine. Where do I even start to look on this thing? I’m thinking this, and my Cat ID quitting are tied together somehow. Is there some ground wires somewhere I can clean? I’ve been taking apart every connection I can find, wire brushing them clean, and putting things back together with no luck. It’s a 97 W900L with a 3406E.
  3. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    The volt gauge is defective.
    Check the voltage going to the gauge in the dash, if possible. If it doesn't match a known accurate voltmeter, its the gauge.
    The voltage is the same throughout the system. Voltage doesn't change, amperage does. That's why you can install a voltmeter anywhere in a system and it will be accurate. This is why it leads me to believe it's the gauge itself.
    SAR Thanks this.
  4. White Horse80
    White Horse80 Bobtail Member
    Not exactly true. While in a normal system it is somewhat true the reading will be basically the same but when you get into the dash you may end up with a daisy chain of devices (ie multiple gauges, illumination lights, gps... ect.)being powered by the same circuit. In an AC system there would be little if any voltage drop. On the DC system a small amount of voltage is lost at each device in the chain also DC voltage does not travel well the further from the source the lower the reading will be. (this is the reason we us AC power in our houses it can be transmitted across the country while if we used DC there would be a power plant every few miles). A defective device in the chain or a weak short (not enough to blow fuse such as weak insulation on a wire) will cause issues getting the proper voltage to the devices at the end of the system branches.
  5. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    I've got a 93 and 97 KW T-600 and both voltmeter gauges will read low for some reason. For example when lights are on truck and trailer both will read 12 volts and when I turn them off it will go back to 13.5-14.
    I have checked with a voltmeter and I have good volts with lights on or not. I run a scan gauge in the trucks and it will show more volts then the gauge on the truck, especially with lights on.
    I haven't bothered to change gauges to see if it helps, but I can understand your concern.
    You could try a new gauge and see if it helps. Good luck.
  6. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    I had the same issues, get under your truck and start chasing cables. I found sections with up to 10 inches of the cable jacket missing. Start at the battery box and work out and forward. All of my cable had to be replaced, over 100 feet of the stuff, all green. This came from the factory like this. I replaced with good copper welding cable, now truck has few if any electrical issues.
    SAR Thanks this.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,297
    Apr 9, 2009
    Humboldt, Sk
    I had one that would run fine with no lights on , then the voltage would lower as you put more of a load on it.
    It was just the alternator, there are several diodes in there, if some of them die, then the output of the alternator is deminished.
    Hulld, AModelCat, SAR and 1 other person Thank this.
  8. BrandonCDLdriver
    1,191
    1,462
    Sep 1, 2017
    I'm sorry but you're wrong. Having multiple devices on the same circuit does not effect the voltage on that circuit. With a voltmeter you will always be checking the voltage in parallel, not in series. If multiple devices pull down the voltage, then the voltage of the entire vehicle is pulled down.
    Take a voltmeter, with the engine off, and check the voltage at the cig socket on the dash. Now, put on all lights and the fan, heck put on the engine ignition. But don't start the engine. You'll see the voltage drop considerably. Now, go check the voltage at the tail lights. It's the same as the cig socket. It's all one big circuit on a vehicle, so voltage is the same throughout. They might have fuses for each little mini-circuit, but they're all tied to one voltage source, a battery or bank of batteries, so the voltage will remain the same throughout.
    Why does voltage remains same over Parallel Circuit
    I'm a licensed airplane mechanic.
  9. AModelCat
    161,652
    Yep. Voltage only drops if you hook the devices in series. In parallel (98% of vehicle circuits are parallel) voltage remains the same. Building off the above principals, corrosion or poor connections act like a load in series with the device and cause less voltage to make it to the device.
    SAR and Justrucking2 Thank this.
  10. AModelCat
    161,652
    I'd start here @Gumper. Get the alternator output tested. Then check for voltage drops between the alternator and batteries while the alternator is producing high output. Make sure to check the ground side too.
    SAR Thanks this.
  11. Gumper
    1,579
    3,845
    Jan 7, 2018
    Butte, MT
    The gauge was reading 14v while driving it home a month ago. It hasn’t driven more than 40 miles since then. I just noticed the low voltage a few days ago while moving it to work on it.
