Volunteering require HOS?
Discussion in 'Trucking Industry Regulations' started by Romeoecho, Aug 29, 2019.
  1. Romeoecho
    Romeoecho Bobtail Member
    25
    29
    Dec 13, 2015
    Howdy. I drive out most of my 70 every week. I'm considering volunteering at a food bank looking for a driver. I'd guess this is a small non commercial vehicle but it's made me curious.
    It they needed a driver for a commercial sized vehicle would I be required to log the hours? If I understand the rules correctly only compensated work for your job needs to be logged.
    Are there any other legality concerns?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Yes. Hours worked in a commercial vehicle must carry a log book record of all employers. You are a volunteer but unpaid. You are still in a commercial vehicle. Which is probably properly registered, stickered and so forth for the highway.
    This is uncommon, but DOT requires a work record of hours at any employer for wages including your trucking work within your 70 hour limit in 8 days.
    Theoratically you could say that you are not working for wages and as such rolling large for free. But it is still a commercial vehicle.
    The only workaround I can see if is your volunteer owner of that organization has that 18 wheeler exempt as a private vehicle. and marked as such. Hauling strictly private things that belongs to owner in any way he gains possession of it. (Not for sale etc Not for ordinary trucking wages etc)
    But carry a logbook record on paper your last 8 days just to be covered. Without one you will be ticketed and probably OOS. If you are driving what turns out to be a full blooded working commercial vehicle.
    Powder Joints and Romeoecho Thank this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Compensation only matters for a non motor carrier.
    If it's a cmv, then even if the company is a non-profit, it's still a motor carrier and all the cmv laws come into play.
    Romeoecho Thanks this.
  5. Romeoecho
    25
    29
    Dec 13, 2015
    Ok thank you . Guess that means I could not help in a cmv. They say only a normal drivers license is needed so there shouldn't be any issues then hopefully.
  6. x1Heavy
    34,016
    42,139
    Mar 5, 2016
    Take a look at the vehicle. What is on it revelant to private vehicle will allow you to run it. Just carry the last 8 days as a defense. I don't know what the truck is hauling, who for, where to and how much. (that's probably private...) but in my mind it's something associated with food pantries and such.
    BE careful another thought occurred to me. The approaching hurricane. If you are being asked to run a truck down there post storm, your truck will need a cardboard sign on door "FEMA use, exempt from HOS etc" and you can drive it until you pass out and keep driving after.
    We had some of those after tornado came through and people made CMV's available to cart the wreckage to landfills etc. under FEMA.
    That I think should lead me to think the first question asked of you is what are you doing with a CMV without being paid?
  7. Romeoecho
    25
    29
    Dec 13, 2015
    I am just looking for some local volunteering opportunities to try to give back to my community. In this case the local food bank is looking for help driving around to pick up donated food.
    I don't expect it will be using a cmv but I've just been trying to figure out in advance if that is something I could offer to assist with if needed. I won't be able to use any hours since I use everything at my job.
  8. ZVar
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Needing a CDL and driving a CMV are two different things. If you are driving a vehicle with a GVWR of 10,001 lbs or more you are driving a CMV and working for a motor carrier.
    If it's 10,000 lbs or less it's not a CMV.
    If it's 26,001 lbs it requires a CDL.
    deathB4decaf Thanks this.
  9. x1Heavy
    34,016
    42,139
    Mar 5, 2016
    Call your State's Commercial Vehicle Enforcement Board and ask for a teaching question before you go out and commit a violation they don't want you to do.
    Tell them what you just told us. They will think and then tell you what to take.
  10. x1Heavy
    34,016
    42,139
    Mar 5, 2016
    On second thought, hop in and drive collecting food as directed. It should be purely your free time, your free use of the skills and the owner of that food out fit should enjoy that the truck is going around serving him, you and all the community when the stuff is packed and bagged and out with the hungries.
    Im involved in minding a pantry myself from time to time. Herding crowds on one hand and trying to unsnarl conflicts on the other.
  11. Ridgeline
    22,633
    120,548
    I have three drivers who drive for Red Cross pro bono on a regular basis, they have to limit their hours in their trucks in order to work for the Red Cross.
    x1Heavy Thanks this.
