Volvo '06 670 inverter problem
Discussion in 'Volvo Forum' started by jardel, Aug 28, 2011.
  1. jardel
    jardel Light Load Member
    110
    21
    Mar 8, 2009
    BUFORD,GA
    i have a volvo 06 ,670 with a invertor from volvo is next to the batteries anyway i change the swich and the braker and it still stays on all the time anybody has any ideea wat's going on .it works 2 min.that is stays on all the time i try turn off and on from the swich nothing ,thanks in advance.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Are you sure it's from Volvo? That doesn't sound right it being mounted by the batteries with the gas vapors generated by the batteries? Plus an invertor has to be in a dry environment.
    But if it is factory, maybe it's wired to stay on all the time while the engine is running. See if the switch works while the truck is shut down.
    If not maybe there is a stuck relay somehwere.
    jardel Thanks this.
  4. jardel
    110
    21
    Mar 8, 2009
    BUFORD,GA
    no sir i was working fine before, it is a dry environment no matter if the truck is off or on is still das the same think i was trying to fix it by myself i have to take it to volvo.the proablem is that their are to expensive and being install by them their are the olny one to work on it.anyway the reasons that i'm asking is that i know that a lots of volvo carry this kind of invertor.
  5. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Volvo had/has a factory mounted inverter option. Mounted somewhat near the batteries external of the cab.
    http://www.todaystrucking.com/decis...15710&intDecisionCenterID=5&CFID=934&CFTOKEN=
  6. 4play
    4play Light Load Member
    90
    12
    Nov 11, 2011
    Edmonton
    did you figure out the problem, mine is doing the same thing, it's the remote plug coming out of the inverter box, volvo is replacing mine under warranty
