Volvo 2007 670 Air compressor problem
Discussion in 'Volvo Forum' started by Meho1969, Nov 11, 2012.
  1. Meho1969
    Meho1969 Light Load Member
    79
    4
    Nov 6, 2012
    St Louis, MO
    :biggrin_25524: Please Helppp!!! I have a 2007 Volvo 670 with an Volvo D12 engine in it. I have a big issue with my air pressure, my air compressor is constantly running, building air up and it purges air every 30-45 seconds. I have so far replaced my air dryer filter (once in June of this year) and I am replacing it now again because it combusted (has two straight lines through the middle like someone cut it with a knife). I have replaced my shut off valve on the air dryer, and the rubber little gaskets that go in the valve. I have also replaced my firewall wiring that is under the hood on the side where the steering wheel is. Recently i replaced the fitting on the compressor that goes from the compressor into the little blue line, and I have replaced the air governor also. None of these things that I have done made the compressor stop building air, nor made it stop purgeing the air every 30-45 seconds.
    Also on a side note since I replaced my air governor my PSI in my air tanks went down from 120 in the tanks to 100 before it purges. Please help I am sick of trying to figure out what is wrong with this darn thing.
  3. Numb
    Numb Crusty Curmudgeon
    4,233
    9,936
    Jan 30, 2012
    Charlotte, N.Carolina
    have an '08, it was some kind of diaphram that they replaced in the air compressor. sounded like it had a cold sneezing all the time!! lol
