Volvo 2014 D13 Steering wheel is lock and won’t start
Discussion in 'Volvo Forum' started by Mason B Trucking LLC, Mar 29, 2020.
  1. Mason B Trucking LLC
    Mason B Trucking LLC Bobtail Member
    Volvo 2014 D13, My steering wheel is lock and it won’t start. Error message come up “neutral secured is not detected”. There is power in the cabin and batteries working great.
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Get another truck to hook to your truck, with key on and with brakes released rock it back an/forth, listen for it to shift into N then try to start it up, all/ways be sure to have truck in N be fore you turn off eng. ?
  4. sirjeff
    sirjeff Medium Load Member
    If this has an I shift, check the pins in the shifter harness connector behind the drivers seat near the floormat/carpet. It is not a weather tight connection and is prone to corrosion from damp floor, wet gloves back there etc
    Mine did it once in a while, then more often, then one day I couldn't get it to start at all. So I cut the plug right out and wired it directly. Problem solved.
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Try Airing up the truck sometimes that helps also like the guy above me said check the pins behind the seat harness if all else fails jump the starter with ign on and it should start make sure wheels are choked.
