Volvo 780 Front air tank keeps draining!
Discussion in 'Experienced Truckers' Advice' started by Midnightrider909, Mar 5, 2018.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    We have never had this problem with any of the other trucks that we have driven. We just bought a Volvo 780 and the front tank keeps draining while we are driving and has to be recharged about every 7 minutes. We are not braking or doing anything that would use air during that time and it does not do it when we are parked even if we have the airbrakes released on the tractor. At first I figured it was a brake chamber or airline that was leaking so while it was parked I walked all around with the airbrakes released and pressure in the system and no leaks. It only does this while we are rolling down the highway. The rear tank never shows a drop in pressure. There is no air leaking from the storage tanks. Any thoughts?
  3. 86mechanic
    86mechanic Medium Load Member
    372
    62,109
    Sep 6, 2016
    Northridge, CA
    Do you have air ride on the front?
  4. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    No, but Im thinking it might have something to do with the air bags on the drives or the cab. Something that’s only acive when driving. It’s maddening!
    86mechanic Thanks this.
  5. 86mechanic
    372
    62,109
    Sep 6, 2016
    Northridge, CA
    That's what my theory was, air bag or leveling valve leaking, when you're bouncing down the road.
    86scotty, Lepton1 and Midnightrider909 Thank this.
  6. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    you did not state what year of truck but they rust out badly from stone chips and salt. How long ago since the airdryer was serviced both are common
    Lepton1 Thanks this.
  7. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    It’s a new truck. 2018 Volvo 780. Probably Should have mentioned that.
  8. Ridgeline
    22,640
    120,691
    Midnight, take it back to a dealer. It sounds like a defective fitting. I run into these all the last one was a brand new WS with five bad fittings and three questionable fittings that the dealer replaced, that truck had less than 200 miles on the clock.
    Midnightrider909 and Lepton1 Thank this.
  9. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    Only doing it while driving would lead me to start looking at the tractor brake system. Most (not necessarily all) everything else wouldn't stop leaking while you're parked.
    Air up, dump the air to your trailer and release your parking brake. Shut off the engine and start searching with your ears for a leak. Then a spray bottle if needed.
  10. cdgoza
    cdgoza Light Load Member
    212
    128
    Jan 24, 2015
    Possibly a brake chamber leaking. Have had a couple do that to me and they only leak while brakes are released.
    Midnightrider909 Thanks this.
  11. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Im at the dealer. 2 leaks getting fixed. Air dryer and back of one of the tanks was cracked. Oh the trouble free joy of driving a new truck!
