volvo 780 fuel feed pressure fault
Discussion in 'Trucks [ Eighteen Wheelers ]' started by melinda824, Mar 11, 2014.
  1. melinda824
    melinda824 Bobtail Member
    16
    We are getting a fuel pressure fault, the truck runs like it has spark plugs with a severe miss it is a d12 engine
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Check your spark plugs! :)
    Maybe a bad/clogged injector. The cylinder needs fuel just like a gas engine needs spark would produce the same results.
  4. nikmirbre
    nikmirbre Road Train Member
    5,398
    9,693
    Jul 27, 2011
    High Point NC
    Had the same issue, turns out I eventually had to replace the pump. But, I can't remember I replaced the something near the manual pump. I assume your talking about the fault with a pump and 3 lines under it on the dash
  5. melinda824
    16
    Thats it, its wierd because we can take the air filter out(the big round one)and it straightens out until we idle for a few hours then we have to do it again. But while it is running like a missing, vibrating boat , it won't change gears, pop the hood take out the air filter and she straightens out.
    We tried to find that symbol in the manual, but couldn't find it. Think it may be a combination of both the pump and the injector
  6. nikmirbre
    5,398
    9,693
    Jul 27, 2011
    High Point NC
    no i believe it has to do with the pump itself…….when i had the volvo d12 I had sooooo many issues with that truck…and that was one of them……thing is I finally replaced the pump and accessory drive, and still didn't fix light coming on….got rid of it 2 months later...
  7. big al 780
    big al 780 Bobtail Member
    21
    st louis mo
    Check if you getting air in fuel if you do then check is in inside engine or outside
    if inside then your injector cups are leaking
    when they injector cups leaking you engine makes noise like you take hand full of change and shake and loses power on heavy loads
    if you adding coolant that may be a problem or check your water separator fuel for coolant
    you can check if you getting air in fuel inside engine but you got install clear lines of fuel and have to use clean fuel from bucket or canister
    and you need to check fuel pressure your pump may be bad or central drive is getting bad
    central drive you can check by removing belts of and see if is any play
  8. goldenotuz
    goldenotuz Bobtail Member
    fuel.jpg Hello,
    My dad is a tucker and hes always asking me to look up information for him while on the road. I found your post, he has a FUEL PUMP and 5 BARS displaying on the DID, is this the same icon you had displaying?
    Thank you for your time.
  9. goldenotuz
    View attachment 77077 Can anyone tell me what the Fuel pump and 5 bars means? Im trying to help my dad while hes over the road. I couldnt find it in the manual.
    Please see the attached image above.
    Thank you guys for your help.
  10. goldenotuz
    View attachment 77078 <- is this the sme thing yoiu are talking about? if not, do you know what it means?
