Hello truckers ! I have Volvo 780 semi truck with Cummins engine, I have huge problem and none of mechanics can not fixed. When I make only slightly right turn with steering wheel its make huge grinding noise. Steering wheel work normal, its not hard or shake. Just making huge grinding noise when make slightly right turn. Mechanic change steer pump and nosie was stil there, then he change steer box, noise was gone for 4 days and come back again ! ! ! Is not make sense ! Is there maybe anything what can cause damage on steering box ? ? ? There is no oil leak or anything, I just dont understand, please help me.
Volvo 780 making huge grinding noise when make slightly right turn
Discussion in 'Ask An Owner Operator' started by surakerestes90, Oct 14, 2018.
What about the u joints? Unless you have to replace the whole steering shaft wich comes with new joints.
Everything in the front end good and greased? Socal mentioned a good point, U joints in steering shaft. A lot of people forget about the one up under the dash and it never gets greased and will cause your steering wheel to bind up and make you think something is seriously wrong.
Dino soar and Rideandrepair Thank this. -
Some models never get greased.......they are nonservicable u joints. The new units have zerk fittings so you can grease them
Rideandrepair Thanks this. -
You might want to check King Pins and all steering parts. Don’t Know what else short of steering column bearings
Jazz1, Grubby and Dale thompson Thank this.
Put thicker oil in the steering pump. Like 15/40. Check if that makes it quiet.
I can not say it will fix your problem.201 Thanks this. -
What sucks is the shop is just throwing parts at it and not properly diagnosing the problem. Find a new competent shop and get if fixed.
Oldironfan and rabbiporkchop Thank this. -
Spring hanger bushings can make a creaking grinding type of noise when you turn the wheel.
Old Man and Oldironfan Thank this.
