Volvo 780
Discussion in 'Volvo Forum' started by Davis6764, Mar 25, 2012.
  1. Davis6764
    Davis6764 Bobtail Member
    18
    Loganville,GA
    I just got a Volvo 780 and can't get the plugs in the sleeper to work, can anyone help?
  3. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Those are for the shore power set up. You plug up the truck to a power source then the plugs in the sleeper work .Sorry , know its not what you wanted to hear .
  4. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    You were talking the 120 plugs, correct ?
  5. Davis6764
    18
    Loganville,GA
    Yes the 120 plugs. Thanks a lot. What about the aux. switch on the dash, do you know anything about that? What do it control?
  6. NRG
    NRG Light Load Member
    166
    46
    May 21, 2010
    Lloydminster AB
    Nothing until you connect them to something (ex. axle lift) You need the power inverter installed and plugged into the main 120 plug, then flip the switch beside it and all your plugs around the truck should work.
