1. Russian Rabbit
    Russian Rabbit Road Train Member
    1,660
    1,589
    Jan 3, 2016
    Is this the port to recharge A/C?
    Volvo VNL if that matters....
  3. baha
    baha Road Train Member
    3,993
    2,627
    Jul 25, 2013
    ga
    Looks like it, the the end of the freon can line will only fit on the suction line.
  4. Russian Rabbit
    1,660
    1,589
    Jan 3, 2016
    Compressor won't turn.
    Let's not do the, "it could be this, it could be that" routine.
    Let's go step by step, most likely, then next likely, then next likely and so on.
    Real detailed with pictures.
  5. JMon
    JMon Light Load Member
    51
    113
    Nov 1, 2018
    Treasure Coast FL
    "POST YO CHECK"list
  6. baha
    3,993
    2,627
    Jul 25, 2013
    ga
    Put a socket on the center of ac comp. An see if it will turn a full turn, if it's locked up you will need a ac comp,, ac dryer.
    Rideandrepair Thanks this.
  7. Rideandrepair
    14,142
    47,009
    Aug 8, 2015
    It’s the smaller of the 2 in the picture.
  8. Russian Rabbit
    1,660
    1,589
    Jan 3, 2016
    i can turn it with my hand. Will try the socket (not even sure if there is a place to put one on.......) tomorrow.
    baha Thanks this.
  9. Russian Rabbit
    1,660
    1,589
    Jan 3, 2016
    Yes, the one in the pic IS the one as i have found out as the can only fits that fitting. However, at this point, i think that is moot as the compressor won't turn when i turn the a/c button on............
  10. Rideandrepair
    14,142
    47,009
    Aug 8, 2015
    It won’t engage without at least some Freon, due to the low pressure switch. If it’s completely empty, it has a major leak. Need to find the leak. First thing is like @baha said. Wrench or socket on compressor clutch center bolt. See if it’s locked up. It should turn, the outer belt Pulley should spin freely. Once you add some Freon the clutch should engage, and the whole thing turns as one. Running the compressor.
    Big Road Skateboard Thanks this.
  11. Rideandrepair
    14,142
    47,009
    Aug 8, 2015
    Some Freon with dye comes in handy. How do you know it’s low? A major leak should leave a big oil spot. Adding Freon to an already charged system is just going to cause more problems. Carefully pushing in the valve core, on the fitting for a split second will tell if it’s charged at all. Protect your hand/ fingers, eyes, from frostbite, and don’t breath it.
  • Draft saved Draft deleted
