Volvo and shredded fan belts
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hunts2much, Sep 26, 2010.
  1. hunts2much
    hunts2much Medium Load Member
    325
    133
    Aug 25, 2008
    Is this a common problem or am I just lucky?
    I'm now on the side of the road in NV holding a shredded fan belt in my hand and it's the 3rd time in a year, and second time in this particular truck. The first time it happened it was a result of a froze up belt tension-er but this time the tension-er is fine. I've caught the problem once, before it could happen in a pretrip and got a new belt (the one that just broke) put on less than 6 months ago. It had a little tear on the edge of the belt but this one was fine this morning.
    I religiously check the #### thing every morning and the belt was fine when I did my pretrip this morning. There are no burs on the pulleys. So what gives? Am I doing something wrong that's causing this? I'm going to start carrying a spare but #### it looks like a royal pain in the ### to put the thing on. If it matters it's a Volvo with the D16.
  3. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    maybe pulleys out of alignment?--or worn pulleys?
    hunts2much Thanks this.
  4. hunts2much
    325
    133
    Aug 25, 2008
    Out of alignment is a possibility I suppose. I've had 2 separate Volvo dealerships verify the pulleys are in good condition but to my knowledge no one (including myself) has verified the alignment. I'll look into that.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,539
    Jul 30, 2009
    Mapleton Depot,PA
    with these newer ribbed style belts alignment is very critical.
  6. hunts2much
    325
    133
    Aug 25, 2008
    Well, upon further inspection the idler (smooth) pulley froze up.:biggrin_25510: Last time this happened it was the (ribbed) tension-er pulley. Last time was also on a Saturday night. I was down for 3 days in BFE WY... wonder how long I'll be down this time....:biggrin_25516:
  7. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    i have the manual tensioner and after 4 years of ownership have never had belts break. I do check them religiously also and change them every 2 years regardless of wear.
    ps. N14 Cummins
  8. dbny5000
    dbny5000 Light Load Member
    87
    55
    Dec 24, 2011
    San Francisco, CA
    Loosen the belts and see which pulleys spin freely and which do not. Pulley alignment is one thing. An idler pulley, tensioner or, for example, AC-compressor clutch that is bad may damage belts. I try to carry a spare tensioner and pulley at all times or be running with ones I know are newish.
  9. Concorde
    Concorde Road Train Member
    4,384
    15,672
    Jun 29, 2016
    West Melbourne Florida
    Your tensioner may look fine but it not be. Possibly it needs a shim..just something that I’d look into. Belts should last years..
