Volvo Boiling batteries?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by R2_, Aug 9, 2011.
  1. R2_
    R2_ Bobtail Member
    28
    Thorndike, Maine
    Any one ever have a problem with Volvos with a Detroit boiling batteries? Sets off all the bells and whistles and shuts the truck down. Is it just me?
  3. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    It sounds like your alternator may be over charging the batteries. You need to get it checked.
    flood Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    Yep, alternator over charging.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what is the voltage? over 15V? it is typical voltage regulator failure....
  6. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,054
    Jul 15, 2007
    TEXAS
    Throwing out a possibility here......The company I'm with had this problem with the new international prostars. Took the truck to the dealer for this same problem. Seems the factory was tightening down the brackets on the batteries, too much.
  7. oilfieldtrash
    oilfieldtrash Light Load Member
    226
    107
    Oct 17, 2009
    Jones,Oklahoma
    It is most likely a bad battery. Heat kills batteries more than cold does. A bad battery can cause an alternator to over-charge. Another thing to consider. If the batteries have any age at all, replace all of them. Older batteries require more current to recharge and will overcharge a new battery.
  8. G/MAN
    7,031
    8,621
    Sep 3, 2010
    I usually try to change all my batteries at the same time, at least if I have had them for a while.
  9. walstib
    walstib Darkstar
    I've had mine boil a few batteries, didn't shut the truck down though, just swelled them and made them spew stinky steam until I replaced...The smell is the tell!
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Just do like Pablo said. If it's over 14.5V it's overcharging. The batteries boiling it's more than that. A voltage regulator that's working will keep it between 13.5 and 14.5V.
    Fix ASAP as an overcharging system can damage your electronics. Then you'll have more repairs.
  11. G/MAN
    7,031
    8,621
    Sep 3, 2010
    It is very easy to check whether it is a battery or your charging system.
