My 98 Volvo has a severe bounce or jerking when traveling between 20 and 45 mph. The problem is worse on a bumpy road and with a load. You can also feel it while driving at highway speeds in a good road but not as severe. It feels almost like the front suspension is loose as it is not a vibration, more or a bouncing and jerking action. I have balanced the front tires and removed the dynamic balancers - made no difference. I am going to start checking things in more detail and plan to start with the front bushings, hangers, springs and bearings. I read something somewhere once that there was an issue with Volvo springs. My springs are almost straight. I guess that is normal?
Can anyone help that has had similar problems?
Thanks
Volvo Bounce
Discussion in 'Volvo Forum' started by FarmerTrucker, Mar 26, 2013.
Did you check the shocks?
Forgot to mention that I also put on new front shocks.
That is a seriouse problem Volvos ride really smooth now it like your in an international
FarmerTrucker Thanks this. -
In between bounces it is smooth! I purchased the truck a couple months ago. The previous owner said he did not have any problems with the ride ( I know and trust the guy). The truck sat for about 7 years. I did rotate the rear duals in case there is a flat spot. But the bounce feels more like something loose or worn and not a rotating wheel or shaft problem - no regular frequency. That is why I am going to thoroughly check the suspension. But if it is the spring, I am not sure what it is supposed to look like.
Thanks
