Volvo - Cannot Parked Regen
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TheCashewKing, Dec 13, 2022.
  1. TheCashewKing
    TheCashewKing Bobtail Member
    Dec 13, 2022
    Hi I have a 2018 Volvo Semi Model VNL. It can't perform active Regen and engine is at derate. Screen is showing Parked Regen Conditions Not Met, Check EATS status Menu and the menu shows System fault: Check
    Had a diagnosis with the software and the following shows up
    I am thinking the EGT sensors from both input and output need to be replaced. Any advices/suggestions? Greatly appreciated.
    Thank you
  3. JB7
    JB7 Heavy Load Member
    744
    1,139
    Dec 13, 2022
    Laurel, MD
  4. JB7
    744
    1,139
    Dec 13, 2022
    Laurel, MD
    Your first active code. This may be causing the other 3 sensor codes.
    P009B Fuel Pressure Relief Control Circuit/Open
    The PCM monitors the fuel pressure regulator and opens the fuel pressure relief valve to return excess fuel back to the fuel supply system. Code P009B is set by the PCM when the Fuel Pressure Relief Control Circuit is open. What is the severity of this DTC? The severity of this code is normally moderate based on the specific malfunction.
  5. TheCashewKing
    Dec 13, 2022
    Thank you for the reply. I have purchased all 3 sensors and plan to replace them first because they are cheaper and easier to install.
    Is P009B a common error code and whats your experience in dealing with it?
    I have attached the diagnosis images since previous links are broken.
    Thank you!
