Hello, I have a 2005 Volvo with D12 engine 13speed eatonfuller
1.5 million miles
truck has no power,
it has good boost
fuel pressure showing good when idling
85psi when reving in neutral.
no codes or any symptoms when parked
As soon as I start rolling some sputtering occurs
with light loads like 5k lbs I have no power, its like hauling 45k and worse...
everything as far as fuel goes has been checked
system holds boost
when i disconect speed sensor the sputtering goes away but still no power.
2007 volvo d12 also 1.5million miles
identical except when I start rolling trucks starts kicking like it loses power and then tries to go at it again... as if bad connection from batteries to ecm but that is not the issue. all good there...
3 injectors were changed recently but problem persists...
this unit even ended up at the dealer and they couldnt figure it out...
when i unplug the speed sensor truck runs fine no stalling/kicking but ofcourse reduced power as speed sensor is unplugged
any ideas????
would the BodyControlModule have anything to do with signaling to the ECM as far as power is concerned... is the speedsensor routed through BCM to ECM or directly to ECM?
anyone have similar issue? could it be bad injectoes on both trucks?
Volvo D12 no power
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Max1989, Dec 11, 2023.
