Volvo D12 short of power gears 9-10
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by NCIA Farmer, Jul 15, 2019.
  1. NCIA Farmer
    NCIA Farmer Bobtail Member
    We have 2 Volvo D12 pulling same size grain trailers. Night and day differance between the 2. The power shortfall is most noticable in gears 9-10. In one mile, there is a 7-12 mph differance, depends on headwind. Both trucks have 425 hp. Had Volvo dealer get hp up to same level. We replaced a EGR valve based on code received. Dealer pressure tested system and identified leaks in the air intake system coming from the turbo. They replaced leaky gaskets, installed a new air to air unit (due to leaks detected) and we replaced turbo, again due to a leak on the fresh air compressor side. After all of this, still terrible performance, most notably in gears 9-10.
    Ideas??
  3. Matt1924
    Matt1924 Light Load Member
    238
    529
    Aug 6, 2018
    Georgia
    My N14 Cummins was doing something similar, turned out to be fuel filter. Maybe check that? Mine had only about 3500 miles on a fresh change when it did this, turns out it had gotten bits of junk and water in it.
  4. Newto Trucking
    Newto Trucking Medium Load Member
    359
    225
    Dec 26, 2013
    NE Illinois
    Fuel overflow valve on a return line from the cylinder head, when it goes bad it doesn’t hold the right fuel pressure for your injectors in a fuel galle
  5. NCIA Farmer
    Thanks. We have less than 3000 miles on fuel filters, but do plan to change them again. Local Volvo dealer did computer check which showed normal fuel pressure levels, but not sure if the pressure reading would detect a faulty fuel overflow valve on the return line. I assume it would??
