Volvo D12 worse MPG
Discussion in 'Trucks [ Eighteen Wheelers ]' started by boborro, Feb 1, 2011.
  1. boborro
    boborro Bobtail Member
    5
    Chicago, IL
    I have 2006 VN670 D12 465 MPG 5.1 with loads 40000 4.6 and speed 64mph, any ideas, there is no codes .
  3. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    The big one is slow down - most but not all trucks will improve by 0.1 mpg by each mph you decrease.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    For D12 55MPH is the best speed. Safey and good fuel milage
    Also check boost lines, intercooler and EGR for leaks
    boborro Thanks this.
  5. boborro
    5
    Chicago, IL
    55 mph in Illinois with 5000 it gave me 5.2 it is not usual for volvo engines, just changed intercooler , before was 4.2 4.5 is there some sensors or someth? Boost lines not leaking...
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Check intercooler for oil spots. If it is D12D turbine sucks oil a bit from cranckase and if there is crack on intercooler you will see oil spot
  7. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Block off the egr!!!!
  8. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
  9. madtrucker1977
    madtrucker1977 Bobtail Member
    st. louis mo
    I gotta '05. 200000 miles ago I unplugged EGR's , bought a flow trough muffler from pittsburg power, slowed down to 61. I also only fuel at pilot and loves, those are the only places tha I never find any water in my water separator and I also noticed
    When I fuel at flying j, petro and especially TA that my hp goes down and fuel consumption goes up. I also use howe's injector cleaner proportionate to every tank. It makes the engine run really smooth with the increase of hp. Besides winter time my fuel cons. Went from: heavy loads 5.5 to 6.4 going west. Going to florida 6.8. Light loads same scenario from 6.1 to 6.9 and 6.5 to over 7
  10. v6killer
    v6killer Medium Load Member
    448
    122
    Dec 6, 2010
    ChicagoLand
    Give Illinois Dyno Center an try, I think they can flash the ECM for better fuel mileage.
    http://illinoisdynocenter.org/Volvo_Trucks.html
  11. vadim2200
    vadim2200 Light Load Member
    128
    36
    Nov 21, 2010
    check exhaust manifold, also when your mpg dropped have you noticed any whistling??
    1976bigred Thanks this.
