Volvo D13 2009 fault code
Discussion in 'Volvo Forum' started by radu, Jul 7, 2013.
  1. radu
    radu Bobtail Member
    Hi, I have truck Volvo 780 with D13 2009,after 2 days idles on dash "STOP ENGINE FAULT" , a fault code with "value too high" ACTIVE : MID 128 SID 25 FMI 0.When I stop the engine a fault code become inactive and I can to erase. After 15 min. idle the engine is stop a fault code its back and the engine is stop. What is the problem?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    external engine protection input active.... usually bad wiring, it is Volvo
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Might be a ground problem, start chasing wires!!
  5. gerardo1961
    gerardo1961 Road Train Member
    1,746
    613
    Feb 21, 2010
    Miami
    You fixed you problem,
  6. chupacabra
    chupacabra Bobtail Member
    24
    7
    Mar 11, 2014
    hello guys i have problem with d13 09 i chance the gasket head ( for oil licks) after chance the engine NOT start , i chance another rebuilt head, the same the engine not start , i chance , start, timing sensor , fuses, harness, another ECM the engine no start , i check injector pulse energy , i chance 6 injector , i check timing fly wheel, and camshaft everthing is ok, but the engine NOT start try with gasoline , ether, nothing !!somebody can help me!!please !!is automatic transmission!!DPF engine !!!any help welcome or idea!!! thanx in advance
  7. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    Sounds like your good at throwing parts at a problem....
    What on earth would make trying it on gas seem like a good idea?!
    Neutral safety switch? Maybe?
  8. chupacabra
    24
    7
    Mar 11, 2014
    you know i chance o'rings piston because by compression but is dead complete,just drop white smog and i can see diesel in exaust head , any idea? j martell? thanx for replay!!!
  9. chupacabra
    24
    7
    Mar 11, 2014
    j- martell doyou where is this safety switch? in i dont know if doyou have diagram about the cab to the ECM ?thank you in advance!!
  10. j_martell
    284
    184
    Jun 12, 2014
    No, I don't, my guess would be somewhere on the tranny(?) I have no idea, I don't have an auto, or a Volvo (depending on who you ask)...im just thinking out loud and hopefully pointing you in the right direction.....throwing money at it hasn't helped, maybe seek professional assistance.....
