Volvo d13 2012 water separator is black after 3000 miles driving wath can be the problem
Discussion in 'Volvo Forum' started by Boromak18, Feb 3, 2018.
  1. Boromak18
    Boromak18 Light Load Member
    62
    11
    Jan 11, 2018
  3. Val77
    Val77 Light Load Member
    52
    25
    Apr 4, 2016
    That is a sign of bad injector cups and O-rings. When you are driving and step on the gas pedal is your bottom fuel mileage indicator going below 6 MPG?
    Johny41, Boromak18 and KB3MMX Thank this.
  4. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    That's what i thought as well, it's the combustion soot going into the fuel side turning it black.
    I'd think bad copper washers not cups...
    Boromak18 and Val77 Thank this.
  5. Val77
    52
    25
    Apr 4, 2016
    Also if you look in the fuel tanks with a flash light you will probably see sooth particles on the bottom and air bubbles coming off the return
  6. Boromak18
    62
    11
    Jan 11, 2018
    Just replace injector and injector caps week ago mechanic say i have some pitting on cap fiting bath new cap is going to sill, maybe is soot left over in the fuel tanks
  7. Val77
    52
    25
    Apr 4, 2016
    What was the reason pf changing the injectors and cups??? Also any difficulties starting the truck?
    Boromak18 Thanks this.
  8. Boromak18
    62
    11
    Jan 11, 2018
    I was having vibration problem and problem with starting the truck and when they start changing injector and caps they say i have pitting on one cap fitting on the cylinder head buth new caps going to sill good and fix the problem, now the fuel milege is much better, truck is driving good only problem is the water separator filter is turning into black
  9. Val77
    52
    25
    Apr 4, 2016
    Fair enough. Your mechanic probably didn't put tge o-rings correctly i think.
    How about your ATS system.......you still have it or its deleted?
  10. Boromak18
    62
    11
    Jan 11, 2018
    If o rings is not install correctly is not going to leak collant also , you asking is bpf delete?
  11. Boromak18
    62
    11
    Jan 11, 2018
    Can the truck drive like that if soot is going to fuel and is going to make demage to the truck
