Hey, We have 2013 D13 with ishift gearbox and having issues with clutch.
When stoping and starting 8 times out of 10 there is a issue with starting driving again. Put it in Drive, selects a gear, accelerating and it feels like the clutch is not engaging smootly. Its like the clutch hesitates to connect with flywheel or not,clutch 10%-30%-10%-30%-and suddenly 100%. The problem is there only when starting from standstill, while driving its all smooth.
Gearbox had been rebuilt by volvo 13 months ago (warranty ended last month), few days ago we replaced clutch control unit on the side of the gearbox, got it calibrated and now there is a fault on the dash, check transmission next stop, it wasnt there before the new clutch control unit. But clutch hesitation problem is still there.
Any ideas, what to check or do before taking the gearbox off?
Volvo D13 2013 i shift rough start
Discussion in 'Volvo Forum' started by jaano90, Feb 24, 2018.
Might be something similar to my problem awhile ago. The brake switch went out of adjustment on the brake pedal causing the transmission to go in and out.KB3MMX Thanks this.
On Thursday at the dealer guy was telling the same story about his truck with ishift, went on a test drive with a senior tech and turned out it was brake switch.
KB3MMX Thanks this. -
Changed the brake switch with the big air valve (5 hose connections) behind the brake pedal, no change.
When i push the accelerator like 5%-20% the engine rpm rise about 50rpm, engine acts like i am moving the accelerator up and down 50rpm, give more gas and then suddenly the truck jumps and goesKB3MMX Thanks this. -
The clutch main bearing was broken.
Ouch sorry to hear that.
Hi I got same problem my truck is running like crazy when I stop my rpms going up and down in few sec 1gear just jump in sometimes 2gr and is noise like crazy start driving for a while then loosing rpms fir one minut and again just start driving normally for few minutes..Do I think is a clutch ?? Thx
What was the issue?
the next post was the issue and it says: "The clutch main bearing was broken".
