Got a volvo d13, engine coolant in cylinder locked. Coolant in oil, pulled pan and could see coolant dripping out of the 2 holes at the bottom of the piston below the wrist pin.
My question is since I have a decent amount of coolant dripping through the 2 holes #6 cylinder only is it possible I also have damaged rings? Or will they leak out those holes are the rings seal tightly under compression of the fuel explosion?
Bad rings along with head gasket and or head?
Volvo d13 coolant in oil
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Transportauto, Oct 25, 2023.
