VOLVO D13 Diesel in oil...any Idea??
Discussion in 'Volvo Forum' started by Mason369, Jan 31, 2018.
  1. Mason369
    Mason369 Bobtail Member
    I just replaced 6 injectors & cups in 7 months ago.. I got diesel In my oil after I done EGR Delete two months ago. Every 4,000 miles I will have to take out a gallon of oil. The engine is around 950,000 miles and it firing right up on first crank every time. In the winter my engine thermostats stay under 150 degree all time... Should I replace O Ring on my injectors???
  3. Oldironfan
    Oldironfan Road Train Member
    5,778
    5,509
    May 22, 2017
    If dealer did your work it should be under warranty of some type. D13 are hard to keep cups working properly. Defect I think but not positive.
    KB3MMX Thanks this.
  4. Diesel Power
    Diesel Power Bobtail Member
    45
    16
    Nov 1, 2016
    Did you try to replace coolant thermostat? Try to do it as soon as possible bcz temp is too low for engine operating temperature.
    KB3MMX Thanks this.
  5. nasriza
    nasriza Road Train Member
    2,116
    1,703
    Feb 1, 2013
    Chicago, IL
    it should be the o rings, most of the time it is the actuall injector leaking right by the solenoid have seen two times the head is cracked but very unlikely on second one, i would suggest open valve cover, remove rockers and all, and then prime up fuel system and check visually for leaks. most of the time you will see which injector is leaking, do as soon as possible cuz fuel in oil at high miles is a death sentence for engine.
    KB3MMX Thanks this.
  6. nax
    nax Road Train Member
    1,999
    2,239
    Dec 14, 2016
    Fuel in oil? <----- that's what Im getting. I just changed the fuel pump, and will dump the diluted oil, put fresh oil, mark the stick, drive 300 mile, and take measurement again.
    I think the OP is talking about oil IN fuel (as in oil getting back into fuel tanks??)....I could be wrong
    P.S. My truck sat for extended periods. fuel pump changed in 2011, and only driven 75K between 2011 & 2017
  7. nasriza
    2,116
    1,703
    Feb 1, 2013
    Chicago, IL
    not posible to be fuel pump on d13 cuz it connects to power steering pump and driven by power steering not gears like it used to be before only place they come together is the head mainly the injectors.
    emilko, KB3MMX and nax Thank this.
  8. nax
    1,999
    2,239
    Dec 14, 2016
    As usual...another home run from @nasriza
    I have a D12A, and that answer gives me hope (that it's not my injectors...LOL)
    KB3MMX Thanks this.
  9. nasriza
    2,116
    1,703
    Feb 1, 2013
    Chicago, IL
    for you i would guess injector o rings it is a very possible cause but i could also be fuel pump as well you can test the old on by applying air to the ports and some soap and water.
  10. nax
    1,999
    2,239
    Dec 14, 2016
    Good to know.
    I haven't returned the core (old one) yet, so that's some good nugget right there
  11. urbanized53
    urbanized53 Bobtail Member
    5
    Sep 3, 2016
    I know this is old post but fuel in oil , I dunno how much you are talking, but can be caused by low idle engine temp. Diesel engines are defendant on friction for combustion. When the block and everything inside warm up they expand, creating higher friction contact, better compression. When it is not to operating temp makes for a looser fit inside, fuel gets pushed past the rings and into the oil pan
  • Draft saved Draft deleted
