Volvo d13 engine swap and ecm question? 2011 into a 2008?
Discussion in 'Volvo Forum' started by alexhemi7, Apr 26, 2019.
  1. alexhemi7
    alexhemi7 Bobtail Member
    10
    4
    Mar 24, 2010
    Hi I am trying to install a 2011 d13 engine that has def into a 2008 volvo with the d13 engine that has only dpf. Will it work? How could i keep just the dpf and eliminate the def since the truck frame doesn't have the def system? Can i use the ecm from the 2008 and put it on the 2011 engine? Thanks
  3. Jacoooooooo
    Jacoooooooo Heavy Load Member
    748
    1,054
    Oct 20, 2013
    It can work. Will need some ecm magic though.
    Not sure if you can use old ecm, but it’s possible to deactivate def on the one from the donor engine.
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Will it work..... yes.
    The motors are identical and an ecm switch is a good idea since you will not need DEF in the 2008.
    You will need the injector codes from the 2011 and input that into the 2008 ECM. I am sure Nas or Quality can chime in with better information.
  5. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    It will work but you need to replace all after treatment fuel valves different systems also Ned to swap injectors and ecm between the two everything else should be good
  6. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Just swap those when u pull the engine out and everything else is all the same.
  7. alexhemi7
    10
    4
    Mar 24, 2010
    What would i have to do to keep the injectors in the original engine? Can the ecu from the 2008 be programmed with the injector codes from the 2011 engine? I also have all the wiring from the 2011 truck cab that i can put in the 2008 truck if i need something.
  8. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    No it Connot parts are different so you will have a lot of headaches with aftertreatmemt.
  9. scissortailed
    scissortailed Bobtail Member
    7
    Oklahoma
    Swapping an 08 d13 into my 07 that had a d12d...
    I got the motor ,frame harness,VECM,and LCM out of the 08 and have all installed.. I've got power to cab and cluster and crank from relay on firewall but no start...
    Tryed to run diagnostic from instrument cluster but operations fail on ECM and vecm
  10. scissortailed
    7
    Oklahoma
    Swapped my 07 Volvo d12d to an 08 d13 ...swapped motor ecm , dpf stack, VECM and LCM and frame harness all from the 08 d13 into my 07 d12d .. I've got power everywhere and crank from the relay on the firewall but no start .. cluster says operations failed between ECM and VECM help... The donor truck was an 08 daycab..d13.. most everything has been plug right in no problems.. why won't this truck start?
  11. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Check chassis harness different also was either automatic. Check fuses in fuse box or cab harness even though it’s plug and play wires do not match.
    scissortailed Thanks this.
