Volvo d13 fault code
Discussion in 'Volvo Forum' started by juanmpvargas, Mar 24, 2017.
  1. juanmpvargas
    juanmpvargas Bobtail Member
    Las vegas nv
    Please help my 2012 volvo feeling weak even with mty tlr, mpg decrease 3.6 to 5 in flats roads code shows SA-0 SPN 411 FMI 3
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    EGR differential pressure sensor voltage shorted high.
  4. juanmpvargas
    Las vegas nv
    Is that problem hard to fix?
  5. uncleal13
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    It's either the sensor itself or a wiring problem to the sensor. On some trucks it's called a Delta-P sensor. Not sure on a Volvo.
    Shouldn't be expensive.
  6. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    it is a delta p sensor on volvo as well but check make sure wires going to it and nothing is blocking the lines with soot. if you have to change the venturi tube there is a whole updated kit it costs about 500 it comes with everything.
    ExOTR Thanks this.
