volvo D13 oil separator has oil coming out from pipe
Discussion in 'Volvo Forum' started by calvint88, Feb 21, 2016.
  1. calvint88
    calvint88 Bobtail Member
    34
    8
    Dec 25, 2009
    I got a 2013 D13 and it has oil coming out from the blow by pipe, there's no code and everything is running normal. I have to add 2 gallons of oil when I run 2500 miles and oil everywhere under the truck and trailer.
    KB3MMX Thanks this.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If you are trying to keep running this truck till you have cash to do a eng. overhaul you can try adding lucus or any of the oil thickeners to keep the oil in it longer, but a broken or worn out part in motor is starting to show
    KB3MMX Thanks this.
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    How many miles on the truck? At 450k ish I had to replace the crankcase vent separator assembly. I was losing a lot of oil but once that was replaced I didn't lose much of any between oil changes
    Good luck
    flood and KB3MMX Thank this.
  5. KB3MMX
    KB3MMX Road Train Member
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    Can the separator unit be drained ????
  6. calvint88
    34
    8
    Dec 25, 2009
    My truck has about 550k, when I pulling a heavy load, it seems to leaks more.
    KB3MMX Thanks this.
  7. calvint88
    34
    8
    Dec 25, 2009
    Thanks for the advice, but I don't think it needs a overhaul yet cause the motor only got 550k on it.
    KB3MMX Thanks this.
  8. calvint88
    34
    8
    Dec 25, 2009
    I believe oil separator can not be drain; the functions of it should be recycling the oil/vapor coming out the crankcase breather tube to the engine.
    KB3MMX Thanks this.
  9. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    I have a cat c13. My truck was doing the same thing. Took it to cat a month ago. I had a crack head. They did a platinum overhaul. But, before that I was using 4 to 6 gallons of oil between changes. I change my oil every 12k mi. If your fuel mileage is good and it's pulling. I would keep adding oil. It's cheaper, than a overhaul. Just my .02
    baha and KB3MMX Thank this.
  10. KB3MMX
    3,076
    2,596
    Dec 29, 2014
    Orrstown, PA
    One thought could be that your truck was one of the Volvo engines that had the bad valve guides problem. Usually the ones with the problem show up before 300k mi but you never know....
  11. letsgofast
    letsgofast Bobtail Member
    25
    8
    May 9, 2013
    for a temporary fix you can take a 1 inch rubber hose and loop it around from the inlet to the outlet of your crankcase filter then just run a hose from the valve cover down i know its a redneck fix but ive done it to a few with 600,000 + miles and they are still running good. Those crankcase oil separators are like $600-$700
    aunimni, baha, KB3MMX and 1 other person Thank this.
