volvo D13 oil separator has oil coming out from pipe
Discussion in 'Volvo Forum' started by calvint88, Feb 21, 2016.
  1. ryanbob1
    ryanbob1 Light Load Member
    121
    35
    Sep 9, 2016
    Well what is the code then?
  3. ryanbob1
    121
    35
    Sep 9, 2016
    Well whats the code then?
  4. Truckers Report Jobs
  5. Amram
    Amram Medium Load Member
    448
    235
    Feb 4, 2017
    spn 153 fmi 7
  6. ryanbob1
    121
    35
    Sep 9, 2016
    That says crankcase vent mechanical system not responding properly, so what work have you done to it so far
  7. Amram
    448
    235
    Feb 4, 2017
    Nothing. It just came in about an hour ago.
  8. ryanbob1
    121
    35
    Sep 9, 2016
    so on the left side of the motor there is the oil seperator sounds like this is your problem
  9. ryanbob1
    121
    35
    Sep 9, 2016
    Thats the oil separator
  10. Amram
    448
    235
    Feb 4, 2017
    I asked volvo if I could take it apart and clean it. They said no. Seems like you could.
  11. Amram
    448
    235
    Feb 4, 2017
    My slobber tube is wet with oil but truck is not leaking. Visual inspection shows no leaks on the housing, interface with engine block is dry and the top hose going to the valve cover has no leaks and is tight. I did just add a gallon of lucas to the truck to see if that may help.
  12. ryanbob1
    121
    35
    Sep 9, 2016
    Inside of that separator there is a spinner and what happens is it slows or stop ie code for mechanical system not operating... We had one on the side of the road and that one was pumping back into the intake at the turbo an thus burning oil and the driver pulled it apart you'll see the little torx bolts around it pulled them off and remove that lid and have a look i havent done this myself but this is what i know from what the driver worked out
  13. Amram
    448
    235
    Feb 4, 2017
    If mine was burning oil would my soot levels be higher on the aftertreatment readout?
