Doesn't mean it related. Antifreeze would dry out by now. Shouldn't cause any problems.
Try to test the sensor, maybe.
What's the mileage?
volvo D13 oil separator has oil coming out from pipe
Discussion in 'Volvo Forum' started by calvint88, Feb 21, 2016.
Page 5 of 9
552,000 on the truck. Well while pulling my cheeses load down to Craplanta the check engine light went away. Im still gonna take that thing apart and clean it though.
KB3MMX Thanks this. -
What oil are you using? -
Btw ... The separator is an emissions type device but not regulated like a catalyst.
You can plug the inlet to the spinner filter .... and put a traditional crankcase vent hose on the truck to the ground... Problem fixed and allot cheaper to eliminate crankcase pressure...sully91 Thanks this. -
I run mobile delvac elite semi synthetic
This issue FOR SURE -- is the OIL SPINNER has stopped spinning - FROZE UP - REPLACE -
Filter is spun by direct oil pressure feed, throwing oil to outside where it drains through a channel to sump, fumes are drawn into intake just before turbo, if filter slows or stops intake suction will draw oil into turbo, when engine is shut down you should be able to hear filter winding down if you listen fairly close to filter, can be stripped and cleaned ,not always a fix but you may be lucky.
I got same problem just put a radiator in mines last week
Page 5 of 9
