volvo D13 oil separator has oil coming out from pipe
Discussion in 'Volvo Forum' started by calvint88, Feb 21, 2016.
  1. Silencer133982
    Silencer133982 Bobtail Member
    Aug 3, 2018
    I am driving a 2016 Volvo leased from penske. The stop engine light came on. checked the oil and there was no oil onn the dipstick. Added oil and It was blowing oil
    Out of the crankcase breather. Roadside service technician sent out by Penske said to tow it in as it seemed like internal engine problems. Penske and Volvo could not find a fault code. So they done mother but change the oil pressure sensor. I picked it up on 7/12/18 drive it for 600 miles and checked the oil it was not touching the stick. Every time I stop oil was running out of the crankcase breather . It done this every 600 miles for about 2590 miles. Then there was a big boom
    In the engine compartment as I was driving on I-70 on indiana. I stop checked the oil and to my suprise it was all the way up to the max level. Keep on mind I only put In one gallon at a time to
    Bring it just within the safe level. Appearently the oil seperator was blocked and by adding fresh oil as it was blowing It out, cleaned and unclogged it. For the next 3k it did not use a drop and no stop engine light appeared. Before that every where I stopped I left a huge puddle of oil. It runs fine now .
    KB3MMX Thanks this.
  2. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    I had had an oil leak and I thought this was coming out of the hose but actually the gasket between the separator base and engine block was leaking, its rubber type gasket that came apart when I took it the housing off, new gasket was about 20$ and not too hard to do it. Just make sure that old paces of gasket don't fall inside engine. I had about 380,000 miles when this happen.
    https://www.amazon.com/Volvo-Truck-20532891-Gasket/dp/B00YJI8UWE
  3. Amram
    Amram Medium Load Member
    448
    235
    Feb 4, 2017
    Forum being wonky
  4. sully91
    sully91 Bobtail Member
    49
    13
    Oct 21, 2019
    Hey. How do you go about doing this?
  5. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Remove the hose from the top of the centrifuge canister and put a plug in it.
    Take the hose that came in the top originally and extend it to the ground using heater hose..
    agustinmyj and Socal Xpress Thank this.
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    That's too complicated :D I don't think I could have figured that out o_O
    agustinmyj and KB3MMX Thank this.
  7. sully91
    49
    13
    Oct 21, 2019
    Copy that. I thought maybe there was a way to put a plate to block off the entire CCV at the engine. I used to do that on my smaller (1.9 VW TDI) Diesel engines. And then run a hose to the ground.
    Do they have blockoff plates like that?
  8. KB3MMX
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    I don't know of any company that manufactures one but you can make one pretty easily
    agustinmyj and sully91 Thank this.
  9. sully91
    49
    13
    Oct 21, 2019
    Might be worth it. Stupid CCV.
  10. KB3MMX
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Lol agreed! They have caused a lot of people grief
