volvo D13 oil separator has oil coming out from pipe
Discussion in 'Volvo Forum' started by calvint88, Feb 21, 2016.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Wonder if extended oil changes has anything to with the spinner going bad? I had it replaced only once at 550k and gone close to 650k on the replacement.
    agustinmyj and KB3MMX Thank this.
  3. sully91
    sully91 Bobtail Member
    49
    13
    Oct 21, 2019
    My spinner spins freely. It’s leaking at the gasket (between engine and metal housing) and that is at 750K+ miles.
    KB3MMX Thanks this.
  4. Paul Chamberlin
    Paul Chamberlin Bobtail Member
    40
    20
    Aug 6, 2018
    Highway
    That will set off engine codes, I did it on my ‘15. I took it apart and cleaned it with dish soap and water the. Re-assembled it. It helped for a short period.
    The excess oil is a sign of more serious problems in the engine. Prob a bad ring or valve allowing too much blow and forcing more oil spray thru the crank vent.
  5. Paul Chamberlin
    40
    20
    Aug 6, 2018
    Highway
    You can do this but expect engine codes. I tried it on my 2015 780. I then took it apart and cleaned it with dish soap and water then blew it out with compressed air. It helped but not for long, I’m sure the excess oil is a sign of too much blow-by. I’m hoping having the overhead run will help me but I suspect it will be a much bigger repair (rings or head)
  6. Caspers Ghost
    Caspers Ghost Bobtail Member
    13
    Jul 8, 2018
    Sorry to revive an old post, but I am having the same issue.
    Engine runs, smokes and blows oil out the blow-by tube.
    Shop here is saying it needs a ring job (bottom end rebuild) and wants $25,000.
    So my question: could this be a bad ring or is this shop trying to rip me off?
    2013 Volvo D-13 580,000 just finished a top end rebuild.
  7. sully91
    49
    13
    Oct 21, 2019
    Hey! My issue was the CCV. The round looking part that sits next to the engine (driver side). I had two bad seals. One that connects the part to the engine and one that separates the CCV from its housing. One is a circle and other is a rectangle looking seal.
    I never had any smoke issue (Knock on wood)... just oil spilling from the engine side.
    Good luck! @nasriza is very knowledgeable. Maybe he is around.
  8. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    @Caspers Ghost what kind of oil are you using and how many miles between oil changes? Replacing the separator is alot cheaper then 25k. Did this shop replace the head?
  9. Caspers Ghost
    13
    Jul 8, 2018
    Mobil Delvac at 25,000 religiously.
    Head was a re-manned swap out.
    Im just trying to figure if I should do the rebuild or if its just this simple fix.
    Little more detail: The truck was under a load. it lost all pulling power and then died. looked under truck and a large puddle of oil. added a few quarts, started up truck and smoke and spitting oil out of the tube (I assume the smoke is from heated oil) got up to about 60 mph and died again. looked and another puddle of oil, did this for about 10 miles and decided to have it towed home.
    (for the days leading up to this, it was having pulling power issues when going up even the slightest incline)
  10. sully91
    49
    13
    Oct 21, 2019
    You have any codes?
  11. Caspers Ghost
    13
    Jul 8, 2018
    none. and no smoke coming from the stacks (is why I think this mechanic is an idiot)
