volvo D13 oil separator has oil coming out from pipe
Discussion in 'Volvo Forum' started by calvint88, Feb 21, 2016.
  1. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Give me a call when u have a chance and I’ll get u some pointers. Phone 6306078889 to much #### going on to write everything on here.
    agustinmyj Thanks this.
  3. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    hey I got the same code, what ended up being the issue?
  4. AlexD13
    298
    85
    Jun 13, 2016
    Had the code come up over a Month ago and changed the Crank Case Pressure Sensor. Now after a month, the code is back. Any ideas?
  5. Derekthetusken
    Derekthetusken Bobtail Member
    4
    How often is recommended to change the oil separator filter?
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    You have another post about a DD13 . Do you have a D13 or DD13. They aren't the same.
  7. BENJI999
    BENJI999 Bobtail Member
    5
    So do u block oil from going to the crankcase and just use the hole in the valve cover to push down a hose for the breater?
  8. Texan4Life
    Texan4Life Bobtail Member
    42
    15
    Oct 18, 2022
    Id just get a new oil separator it is worth the money, I had the same issue started losing a lot of oil. Replaced it and I'm back to not adding a drop of oil between changes. truck is at 750k and 29k hrs with no blowby.
    You can verify by having the truck warmed up to temp and then take the oil fill cap off while idling. I'd bet you have little to no blow by, and it is the separator is broke and not spinning (its a centrifuge powered by engine oil pressure).
  9. BENJI999
    5
    I replaced the oil separator twice already i dont have any blow by or smoke coming out the exhaust it's driving me crazy
  10. Texan4Life
    42
    15
    Oct 18, 2022
    Ah okay yeah I would definitely be frustrated.
  11. BENJI999
    5
    D13
