Volvo D13 turbo question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by maxya1986, Mar 24, 2015.
  1. maxya1986
    maxya1986 Light Load Member
    73
    13
    Feb 17, 2015
    What's the symptoms of bad turbo? Truck is driving well. There was some codes for turbo on it. Could it cause big fuel consumption? While truck idling I can hear that turbo starting to whistling then it stops and start again and do it repeatedly. Fuel consumption even while idling is 1.5 gph. And on the highway around 5.5 mpg which is pretty high for that engine. May turbo cause such problems? Or turbo actuator? Or EPG (but engine break works perfectly).
    Thank you
  3. maxya1986
    73
    13
    Feb 17, 2015
    I never had problems with turbo before, so I don't know how to check if that's a time to replace it cause I won't do it on the road
  4. maxya1986
    73
    13
    Feb 17, 2015
    Code I have spn 102 fmi 18 which means low intake manifold pressure I think
  5. maxya1986
    73
    13
    Feb 17, 2015
    Or could it be exhaust pipe clogged?
  6. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Get it to a shop. There is a problem either with the turbo itself or the turbo actuator. Yes, it will cause bad fuel mileage
  7. maxya1986
    73
    13
    Feb 17, 2015
    Still very bad fuel mileage, average around 5.5 mpg. Engine D13. Any ideas what may cause that?
  8. DUNE-T
    DUNE-T Road Train Member
    6,885
    16,634
    May 10, 2015
    Detroit, MI
    Dude, take it to a good mechanic instead of playing guessing game on the forum
  9. gurdev
    gurdev Bobtail Member
    8
    sacramento
    mine was same problem dealer changed head gasket and now m getting 7.1
