I have a Volvo D13, its starting and immediately cutting out. The fault codes are fmi12, pid 224 - security system failure. Can anybody help?
Volvo D13a fault codes fmi 12, pid 224, mid 128
Discussion in 'Volvo Forum' started by Amushonga2000, Jan 27, 2014.
For some reasn your engine ecu and the dash are not the same page , it wants to see a security code from the dash and its not , the code says it has a failed ecu , it could be the cluster or engine ecu , I would start looking at the engine ecu plugs on the ecu to see if there any oil in them from a sensor leaking up though the pins , like oil pressure sensor and also they had a problem with the injector pass though from the head leaking down though the harness , and also make sure al powers and grounds are tight
Thank u Markster1957, will check and let you know!
wrong key, wrong VIN in any ECU
Amushonga2000 Thanks this. -
Is it worth disabling the vehicle security in the engine ecu so that the key can work in case the transponder in the key is damaged?
What version of Vcads would u recommend for D13a and where can I get it? Thank u!
it is impossible to disabel engine security with VCADs. For example if u swap LCM from other truck engine wont starting!
ok, what a truck, what year? what VIN -
Volvo fm13-440, 2006, UK model, VIN yv2js02c76a623615
First time it occured, it had just been started up and had been running for under 10min before it stalled. We diagnosed a faulty relay. It was replaced and it ran fine afterwards. Now it stalled and wont crank. Relays are checked and all good.
Did you come right?
