Volvo D16 Head gasket problem? Assistance Needed.
Discussion in 'Volvo Forum' started by madd_trucker_herk, Jul 20, 2014.
  1. madd_trucker_herk
    madd_trucker_herk Bobtail Member
    NC
    I have a 2008 Volvo with a D16 motor. I was wondering what are the symptoms of a blown head gasket? The motor is skipping and I have to put two gallons of water into it a day. Any help would be appreciated.
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Did you check the oillevel?
    Dryver Thanks this.
  4. 201
    201 Road Train Member
    12,263
    25,041
    Apr 16, 2014
    high plains colorado
    Hi madd, 2 gallons a day is extreme. If it's not leaving big puddles, the only other place it could go is through the motor. If it's going into an oil passage, you'll have that brown glop on your dipstick, otherwise ,it's going out the stack. Now, people may lambast me for this, but I've used a product called "Mend-Tite" sealer. It's available at Bumper to Bumper, and other places, I'm sure, and it sealed up head gasket leaks many times for me. It's not a permanent fix, but does a good job of slowing it down. Might give you time to put away some cash to have the gasket replaced someday. If it's mixing with the oil, you are kinda screwed. Good luck.
  5. poniikyanion
    poniikyanion Light Load Member
    69
    14
    Nov 23, 2009
    Newark, NJ
    May be your egr cooler is bad and leaking coolant.
