Volvo electrical issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by reddemon71, Feb 5, 2008.
  1. reddemon71
    reddemon71 Light Load Member
    79
    8
    Feb 5, 2008
    Mpls,MN
    I see alot of truckers talking about electrical issues on these Volvo's, Does this include the 2004,2005 model years also? I'm wanting to buy a 2005 volvo but kinda hesitant now after seeing all the remarks.
  3. D16
    D16 Light Load Member
    188
    8
    Jul 11, 2007
    Vancouver
    Have mine for 1.5 years.Actually not experienced any serious electrical problem.ECM just report any faults at display.I believe if Peterbilt or KW,Western Star had same display on dashboard,they would have same "electrical issues".:biggrin_25525:
  4. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    Maybe that electrical display is having issues :yes2557:
  5. Sandlapper
    Sandlapper Light Load Member
    208
    35
    Feb 6, 2008
    Simpsonville, SC
    The problems are with the D-13 Volvo Engine. I think the problem is with the EGR valve. The newer models have a recall on the cooling system and the computer's parameters. To be honest I see more Freightliners on the side of the road with the hood up than I see Volvos in a similar situation. In an 04 or 05 model I would go with the Cummins. I think they quit using Detroits in 03.
  6. cuzzin it
    cuzzin it Road Train Member
    3,639
    11,737
    Jan 19, 2008
    Berea, KY
    i worked for a company with Volvos, many had dash readout probs, minor stuff. They are well built trucks
    KB3MMX Thanks this.
  7. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    It's all minor when you aren't paying for it
    KB3MMX Thanks this.
  8. cumminsvolvotech
    cumminsvolvotech Bobtail Member
    6
    Aug 23, 2008
    Denver, CO
    The majority of electrical issues are caused by loose or dirty battery / ground (block, frame, starter, etc..) cables. CLEAN AND TIGHTEN YOUR BATTERY CABLES!!!! I can't stress this enough!
    KB3MMX, The Challenger and Who Thank this.
  9. AntonD
    AntonD Bobtail Member
    Chino, CA
    Iam also having problem with my 2005 Volvo VNL780, it all started with a flickering headlight then dashboard lights. Telltales started to show different fault problems then the radio, A/C, dashboard gauges is also getting crazy.I need help cummins volvo tech
    thanks
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    See post above yours. Sounds like you lost chassis ground or the hot. An 1/8 of a turn and some corrosion under the nut/bolt is enough. It started with the headlights flickering because it uses the most juice.
    Check the hot at the starter by actually putting a wrench on it. In the dark, you might see sparks at the nut while cranking the starter if it's a hair loose.
    The same with chassis grounds. Use a wrench, not your eyes. Follow off the battery to the frame. Then check the ground strap under the hood.
    Last, check the hot at the jumper block under the hood. Then check the main hot at the fuse block.
    Ignore the fault codes for the time being, because there are low voltage and high voltage faults that can be triggered from a bad connection.
    After you have checked all the connections with no luck, then have diagnostics run on it.
  11. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    all Version-II, VN, FH, FM. But with d13a and D9B more problems
    KB3MMX Thanks this.
