volvo epg1 problem
Discussion in 'Volvo Forum' started by jaielv, Jul 15, 2012.
  1. jaielv
    jaielv Light Load Member
    62
    12
    Dec 30, 2010
    joliet,il
    new problem on volvo 2004 d12d volvo engine .epg1 message comes on I notice some kind of air noise from turbo when i accelerate.I called dealer for price on the epg its $900+ us and 550 for the epg air valve.what will be the correct way to check . i read in another forum u apply air to epg and whatch if it closes.what about the air valve how is this check I will hate to replace the 2 units with out needing to.what issues might this cause. thanks for any help
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    what is the full MID 128 code?
  4. jaielv
    62
    12
    Dec 30, 2010
    joliet,il
    mid 128 sid 146 and mid 128 ppid 124 thanks for respond pablo
  5. sbaumann14
    sbaumann14 Road Train Member
    1,222
    1,413
    Sep 1, 2010
    Rhinelander, WI
  6. jaielv
    62
    12
    Dec 30, 2010
    joliet,il
    ok so how can I check the epg1 and air valve price for this are kind of high epg is $950 and air valve that controls the epg is $550.if it helps I do hear air from that area every time I accelerate .this sound started about the same time I got the epg message.
  7. Mleejr
    Mleejr Bobtail Member
    Dis you ever figure out how to check them both? Im having this same problem
  8. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    If you get a loud noise from the turbo area when you accelerate, it's either a cracked EGR cooler flange, cracked EGR cooler pipe or broken EGR cooler pipe clamp. When the EPG valve on the exhaust goes bad, you get an air hissing noise coming from inside the exhaust system at idle when the engine is cold.
