Volvo factory installed inverter.
Discussion in 'Volvo Forum' started by Echo5kilo, Feb 26, 2021.
  1. Echo5kilo
    Echo5kilo Bobtail Member
    46
    47
    Sep 8, 2019
    I believe it's 1800 watts. Is it okay to run lets say a air fryer that's 1,700 watts?
  3. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    That's probably pushing it.....it will depend on the quality of the inverter, wiring and if its a pure sine wave or not. It might work if it's the only thing plugged into and drawing off the invertor but my bet is it will cut out before your fries are done.
    86scotty and Echo5kilo Thank this.
  4. Echo5kilo
    46
    47
    Sep 8, 2019
    And I'd be no end of pissed off.
    I figured it was too small. They have some 3500w in the shop. I might see if they can hook me up.
  5. 86scotty
    86scotty Road Train Member
    4,552
    12,356
    Aug 27, 2017
    Appalachia
    Did you try it at least? You probably won't kill anything, your inverter will just beep and/or shut down. Try turning down the air fryer and cooking for longer, and cook with the truck idling to keep the power stream constant.
