Volvo fl 6 220 of 2004 stops
Discussion in 'Volvo Forum' started by josia, Jun 16, 2014.
  1. josia
    josia Bobtail Member
    i own a volvo fl6 220 truck of 2004. it doesnt start and when it starts, it runs for just 3 seconds then it stops. it also has a message data link broken. what could be the problem and how do i fix it?
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I would start with checking the ECM hot wire at the battery. It's the little wire. Sometimes the little connector crimp on the end can fracture from repeated vibration. Wiggle it and see if it breaks off. Also check for corrosion on the connection. A little up the wire should be an inline fuse. If it starts then quits the fuse is good but there might be a corrosion issue there too.
    Other than that I would think it was a fuel problem if it wasn't for that message.
  4. lucemm
    lucemm Bobtail Member
    Hello
    Sorry I can't help with your problem but I have a question about my FL6 220 and can't see how to start a thread
    Hope someone can help please
