Volvo gauge cluster vs speed?
Discussion in 'Volvo Forum' started by S M D, Jul 16, 2016.
  1. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    So before I waste my time at a Volvo stealership here's the low down .
    Put a new trans into my 06 670 speedo is way off compared to actual speed 74 mph gps actually shows 81 on the cluster. ..
    Sooooo questions
    Would this be a speed sensor issues or would they be able to program it recalibrate by plugging it in.?
    It's annoying because Im either driving too fast or too slow lol.
  3. Trkr3529
    Trkr3529 Light Load Member
    104
    66
    Feb 14, 2016
    Was the transmission the exact same model? If it wasn't it could have a different final drive ratio that could put it out.
    I would doubt the speed sensor would do that, usually they either work or they dont
    S M D and flood Thank this.
  4. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    Tire size ...
    A augocom h8 adapter with software is less then 300usd ink shipping ...
    S M D Thanks this.
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Prob Transmission output shaft teeth are different so it's not calculating proper speed. need some good reprograming by someone that knows what the hell they are doing and you'll be all good .
    S M D Thanks this.
  6. S M D
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Yup figured, I stopped by at volvo in Cheynee wy and they wasted an hour of my time telling me how it's easy to do it on the cat motor lol. It failed so when I get back to Cali I'll take it to Volvo and see if they can do it
  7. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    On a Volvo truck 2006 the information who can affect the speedo is located in the parameter of the VECU they call K-Facto, the VECU share that information with the EECU.
    K-Factor= Turn per mile of rear tire X rear axle ratio X transmission output shaft tone wheel.
    You should do the calculation with a calculator and then program that big number in the VECU parameter with the proper tool.
    Note: Fuller transmission use 16 teeth tone wheel and Volvo I-Shift transmission use 6 teeth tone wheel for the output shaft.
    The accuracy of the Volvo cluster (speedo) is +3 km -0 km
    Ben
