Volvo: Hill Holder - Fault Codes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by vanostav61, Apr 18, 2022.
  1. vanostav61
    vanostav61 Bobtail Member
    32
    14
    Mar 22, 2022
    Hey everyone, the hill holder on my truck is not working and I found these fault codes SID-94 and SPN-2622. The codes are constant, any idea what I should look for?
  3. 201
    201 Road Train Member
    12,641
    25,975
    Apr 16, 2014
    high plains colorado
    An old Studebaker?
  4. Grumppy
    3,176
    11,086
    Dec 11, 2010
    West Monroe, La
    I'm gonna see how close I am.
    I suspect this is going to be a software issue. I would think there is some mechanical functions involved but its brakes. If your brakes are working properly, then its a software issue. If that's the case, you'll need to take it to a shop & let them repair the issue within the software.
    We'll hear from some real mechanics before long I hope.
  5. wichris
    wichris Road Train Member
    4,439
    9,101
    Jan 17, 2011
    HSA should be combined with the ABS
  6. vanostav61
    32
    14
    Mar 22, 2022
    ABS and brakes are working fine. Hill Hold doesn't respond to any button actions.
  7. loudtom
    loudtom Road Train Member
    1,717
    2,805
    Aug 26, 2016
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10169013-9999.pdf
    This explains a little about how the system works. Usually there's an FMI with the SPN to help narrow down where to start, but I've never had to deal with this code. As long as the brake system works properly, I wouldn't dig too much into it if it were my truck. It's like driving without cruise control, it might be annoying, but you can still run the truck without it.
    If I felt like I had to look into it, I'd start with the hill start assist solenoid.
    https://static.nhtsa.gov/odi/tsbs/2014/SB-10055990-9663.pdf
    Test the wires before changing the part. There should be one from the ABS, and another to a common ground on that connector. If you think the part is the issue, make sure you get the correct part number for your vehicle from the dealer. If you want more specific guidance, go to the Volvo media site and search for "hill start" documents that apply to your truck.
    vanostav61 Thanks this.
