Volvo I-shift problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jake892210, May 2, 2020.
  1. jake892210
    jake892210 Bobtail Member
    Hello, We have a 2005 Volvo fh12 with i-shift gearbox with very slow changes, otherwise its lovely up and down with no issues, and smooth with no bad noise ect and no fault codes...
    but it changes way too slowly and when plug in volvo software and try and run a gear shifting test, it times out saying "taking too long to shift",
    (for example if i was driving a manual and put the clutch down like normal and then took a few seconds before i selected the gear and let the clutch out, that's what it does....
    its a major issue as fully loaded it will get stuck in an endless cycle selecting a gear and then back down to a lower gear where its lost the momentum!
    any pointers would be greatly appreciated
  3. SergeyN
    SergeyN Bobtail Member
    17
    Apr 18, 2020
    remove the transmission and replace the CCA(clutch cylindre activator)
  4. SergeyN
    17
    Apr 18, 2020
    if you remove the box, I would check the clutch and the box itself
  5. SergeyN
    17
    Apr 18, 2020
    but before removing, you need to make sure that there are no other obstacles to the air - tube modifications - and you can check the CCV before removal, through the hole when the CCV is removed, you can check the CCA - all this is in the technical guide upload_2020-5-3_11-44-30.png
