I have 3 LCM codes: MID216 PSID10 FMI5, MID216 PSID11 FMI5 and MID216 PSID48 FMI5. I have a 2005 Volvo ISX 450. I had the stop/signal lights on th cab changed with LED looks like this trigered something. The bad part is that the revers light doesn't work and looks like i don't have any power coming on the reverse wire. And i just found out that the stop lights on the cab and one signal light on the trailer are half way on (you can not see them in day light but a close look at night u can see that are a little light up).
Volvo LCM codes and lights problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dani, Feb 21, 2013.
Just had a problem similar to this with our Volvo. I found a spot in the wiring along the inside of the frame rail near the output of the transmission where the wires were secured to a bracket. There was a loop in the wires and it was worn thru four of the wires. it was shorting the wires to the frame causing some real gremlins of issues with lights.
I suggest to inspect the harness from front to back to check for wear spots and shorts. It took me about 2 hours to trace down a simple problem.Dani Thanks this. -
I will try that as soon will be a little warmer. I'm in Chicago. Any other sugestions are welcome. Thanks
any other sugestions?
