Volvo only engages ODD GEARS..EVEN GEARS feels like NEUTRAL
Discussion in 'Ask An Owner Operator' started by KEVIN S, Jul 10, 2024.
  1. KEVIN S
    KEVIN S Bobtail Member
    15
    9
    Apr 2, 2021
    2016 volvo D13...yesterday got message CHECK TRANSMISSION AT NEXT STOP..Busy intersection..cops already called TOW..Somehow erratic transmission kicks in...NOW good in gears 3 5 7 9 11..BUT 6 8 10 12..feels like Neutral..AND 1st TANK losing air WHEN building...started yesterday COINCIDENCE...?
    HELP WILL BE APPRECIATED
  3. Siinman
    Siinman Road Train Member
    5,420
    13,801
    Mar 5, 2017
    Kansas City, MO.
    I am not understanding on the air. If it is too low it will not allow the transmission to work. So this could be part of the problem. Also sounds like the TECU ribbon is not communicating and might need to be replaced. Or could be time for a rebuild on the transmission. How many miles on it and was it serviced at the 500K?
    77fib77 Thanks this.
  4. KEVIN S
    15
    9
    Apr 2, 2021
    Air is good now. All ODD gears all good. But If it shifts to a EVEN gear 2 4 6 8 10 12....feels like Neutral. No grinding or Noise. Driving to HOME TERMINAL in 11th gear...Cruise at 53 MPH. Truck Mileage is 860000. Yes it was serviced at 500k..Transmission cooler lines changed......THANKS
  5. 86scotty
    86scotty Road Train Member
    4,570
    12,440
    Aug 27, 2017
    Appalachia
    That's odd.
    Numb Thanks this.
  6. KEVIN S
    15
    9
    Apr 2, 2021
    Yes..Truck at Mechanic...still fishing
    Any ideas...U think transmission is good?..I mean all ODD gears NO ISSUE
    ...Harness maybe..?
  7. Siinman
    5,420
    13,801
    Mar 5, 2017
    Kansas City, MO.
    @nasriza you have any ideas on this?
  8. KEVIN S
    15
    9
    Apr 2, 2021
    @nasriza You think i can drive in ODD gears to Chicago to you. 400 miles
    The CODE is SA24 DTC P107538
    Thats for CLUTCH
    But why CLUTCH bad ONLY for EVEN gears
  9. 86scotty
    4,570
    12,440
    Aug 27, 2017
    Appalachia
    Unless you're pulling a loaded trailer you can drive a rig in odd gears pretty much forever. That would be the least of my concern if everything else is fine.
    Unfortunately you won't have 12th though. You're gonna eat some fuel.
    KEVIN S and Siinman Thank this.
  10. Siinman
    5,420
    13,801
    Mar 5, 2017
    Kansas City, MO.
    I agree on this. Should not be a big issue unloaded as long as it does not keep trying to go into the gears.
    KEVIN S Thanks this.
  11. Siinman
    5,420
    13,801
    Mar 5, 2017
    Kansas City, MO.
    Do you have the option of shifting gears manually? I am guessing you do and have tried this and this is how you figured out the issues with the gears?
    KEVIN S and 86scotty Thank this.
