Hello..
just have to comfirm with the volvo FM12 D12D tractor trailer lamp wiring connection direct from cabin light ECU? cause all the trailer light mulfunction.
thanks.
best regard.
volvo tractor trailer lamp
Discussion in 'Volvo Forum' started by ah fai, Dec 26, 2012.
what lamp? post a pic
Tractor trailer light, trun signal, brake, reverse.... i used with LED light and someone told me that the light ECU cant detact the light load amp, just make a setting with volvo PTT. is that true?
I tried putting LED bulbs on work lights on the back of my cab. it kept throwing codes. Not enough voltage draw using LED's so throw's a code. Went back to regular bulbs . no problems.
LCM must be reprogrammed for LED
