Volvo Tri-Pac
Discussion in 'Volvo Forum' started by LMB, Jan 23, 2015.
  1. LMB
    LMB "Olde Goat"
    1,692
    897
    Aug 12, 2007
    Rocky Point NC
    2009 volvo vnl64t, I have no power to the control panel for the Tri-Pac apu. Any Ideas. Checked all fuses in black box under bunk all ok
  3. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    Did you check the main fuse holder by your battery?
  4. bjytech
    bjytech Light Load Member
    240
    221
    Nov 9, 2013
    In the back of the tri-pac box behind the motor and above the alternator there is a big 50amp fuse to check and the fuse holder for it likes to corrode inside as well, it can be a real bugger to get to sometimes. While your in there check the connections on the alternator and starter as well, both are common problems.
    Power for the control panel runs like this: Batteries --> APU starter --> APU alternator --> power post in black box --> control panel
  5. LMB
    LMB "Olde Goat"
    1,692
    897
    Aug 12, 2007
    Rocky Point NC
    No fuse holder by battery. Cables go from battery to factory installed inverter/charger to apu
  6. LMB
    LMB "Olde Goat"
    1,692
    897
    Aug 12, 2007
    Rocky Point NC
    I will check that out. Is the 50 amp fuse an item that can be obtained without going to volvo, or TK?
  7. bjytech
    240
    221
    Nov 9, 2013
    Yes, most any auto parts store should carry them
  8. LMB
    LMB "Olde Goat"
    1,692
    897
    Aug 12, 2007
    Rocky Point NC
    Again, thank you all for great information
  9. Tuzla075
    Tuzla075 Light Load Member
    60
    17
    Dec 4, 2012
    View attachment 77742 There is your fuse that could be the one you r lookin for. Had same problem, and it was easy to find, just on the top of the batteries, it is inside plastic cover holder, and it is red. Hope it helps.:biggrin_255:
  10. LMB
    LMB "Olde Goat"
    1,692
    897
    Aug 12, 2007
    Rocky Point NC
    won't let me see the attachment
  11. Tuzla075
    60
    17
    Dec 4, 2012
    Sorry, i guess I do not know how to post the picture here, but it shows when I click on the attachment.I ll try again, see if this works. View attachment 77748
