Volvo VNL 04fan clutch solenoid energized all the time from the ecm on a cummins ISX
Discussion in 'Volvo Forum' started by trikefloats, May 28, 2014.
  1. trikefloats
    trikefloats Bobtail Member
    7
    Fan clutch solenoid energized all the time from the ecm. Already melted one solenoid. The new one stays hot around the clock unless I disconnect the batteries or remove the ecm plug. It doesn't go through a fuse. I disconnected the temperature sensor. No change. My feeling is the ECM has malfunctioned somehow. Does anybody know what will be the best approach to resolve this problem. I will appreciate any ideas. THANKS!!!!
  3. chp56
    chp56 Light Load Member
    150
    33
    Sep 25, 2011
    Barstow, Ca
    My Freightliner had the same problem--had to replace temp. sensor (located by a.c. compressor)
    trikefloats Thanks this.
  4. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Best way for that issue go to cummins sometime isx engine have a tendency to burn up the ecm and they either don't run fan at all or all the time depends but cummins is pretty good at it
