Volvo VNL 670 - No A/C To Sleeper
Discussion in 'Volvo Forum' started by G 85 Camaro, Jun 4, 2018.
  1. G 85 Camaro
    G 85 Camaro Bobtail Member
    10
    Hello all,
    We have an issue with our truck that when we turn on the fan in our sleeper, we only get heat and no A/C whatsoever, although we have the heat turned off on the control console. The dash of the cab works fine, just not the sleeper area. Any recommendations?
  3. Bcrawford865
    Bcrawford865 Bobtail Member
    6
    Jun 5, 2018
    Under your bunk there is a box for the AC in the rear. On the top of that box you have what is called a Stepper Motor. When you turn the control to cold in the sleeper that stepper motor has a valve in it and it turns the fins inside it cutting the hot air off and only allowing the cold air through. For a quick fix, you can take that motor out “it’s only two star screws” and find you something to hold the fins closed. You just won’t have heat.
    G 85 Camaro Thanks this.
  4. G 85 Camaro
    10
    Thank you for this. Our truck is missing the stepper motor, but I found the valve you're talking about and that fixed the issue for now.
