volvo vnl780 with pre emission cat motor?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by marek4792, May 21, 2011.
  1. marek4792
    marek4792 Light Load Member
    62
    31
    Mar 21, 2011
    Chicago, IL
    i know that its kind of a stupid suggestion, but what are the possibilities of one pulling off such an attempt of putting a lets say an early model c-15 or a 3406e into a late model 780? pos/neg comments welcome:biggrin_25519:
  3. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Anything is possible with the right motivation and money.
    Things may get very interesting if there is a trans or chassis computer involved.
  4. dieselpowerrules
    dieselpowerrules Light Load Member
    248
    37
    Feb 24, 2011
    Wisconsin
    Those modern Volvos are nothing more than a rolling computer on wheels, I highly doubt that would work, but I'm sure someone would know more than me...
  5. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    Beyond question you could make it run and drive. I'm not sure how hard it would be to make the dash fully functional. I would suggest contacting these people and get their opinion on whats possible.
    http://www.mawkindustries.com/index.htm
    marek4792 and Strider Thank this.
  6. marek4792
    62
    31
    Mar 21, 2011
    Chicago, IL
    thanks for the comments, i was thinking it could work more like the 770's did back in the day when they had a contract to put cats (3406e) in them for a few years, gotta love the low-end torque a cat delivers. but as of now it's on my to do list and thats gonna be awhile from now until i save some money and a lot of time to experiment with it.
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    one thing you will have to meke yourself: Cabine-engine wiring, no this part for CAT is available. The next step - get reason 3-4 passwords for your engine and change engine control to by the J1939, enable PTO (else cruise controll will not work) and change speed sourse to J1939. Do not forget to preogram top gear ratioo of transmission.
    Look carefully at VECU controlled relay wiring, D12 engines power is controlled with K2 relay, cumming engine is supplied from battery box and no relay is used. it depends on what engione was before CAT
    Range downshift protection is programmed in VECU so disable all unused in and out pins.
    Do all this stuff becouse on volvos engine is VECU controlled. If there was Volvo engine before CAT get VCADs pro to change engine type in VECU to other ore cummins.
    Well, Volvo made VECUs for cat, but these VECUs are rare on Version-II and as I can see newer VECU works fine with any J1939 controlled engine, I did D12D to D12C and D12F swap, I did D12D to N14 swap and I did Series 60 to D12C swap. With some hidden traps all work finally well.
    I cant advice you anything about engine mounts, fans, radiator hoses becouse I did wiring works and programming only, but I can ask mechanics who did this swap about this
    The Challenger and marek4792 Thank this.
  8. marek4792
    62
    31
    Mar 21, 2011
    Chicago, IL
    good to know Pablo! cant wait to hear from you.
