Volvo VNM64T D13 Drinking Fuel, Injector (cup) issue?
Discussion in 'Volvo Forum' started by GaryP, Oct 18, 2013.
  1. GaryP
    GaryP Bobtail Member
    Hello All,
    I've got a 2010 VNM64T with D13 with 115000km on it.
    I use to average about 43-45 ltrs/100km. The truck had a problem, injector cups were replaced and injector #4 was changed as well. Since then the fuel economy has gone to ####, averaging about 68 ltrs/100km. The soot level fills up after about 200km or 10 engine hours and the regen process kicks in / has to be run. Every second day right now I need to run the regen. I've had the DPF removed and cleaned and still no change in fuel economy.
    Before changing the injector cups and injector #4 regen use to run after about 500km and fuel economy was much better using only 45 ltrs/100km.
    Any idea what the cause of this may be? The truck seems to be using a lot more fuel and a lot is left unburnt and filling up the soot level.
    Thanks,
    Gary
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    When tey dod youre injector cups and changed youre injector they also probably did a tube up on the truck adjusting all the valves injectors and such the problem i think is there i dont think they set up the valves the correct way maybe they tight up the untake valves a little to much also try to clean out ure 7 injector and is it also possible if the truck was leaking coolant in the combustion then it loaded up the filters a bit i would day have youre valve adjustment checked to help out eith the fuel a bit u need to set intake valves little loose and exhaust a little tight
  4. GaryP
    Looks like it'll be going in to Volvo for them to check out / diagnose whats wrong and maybe a valve adjustment too :(
    Being out of warranty sucks.
  5. tirexpress
    tirexpress Light Load Member
    91
    24
    Jul 31, 2012
    Montreal, QC
    I would check the the exhaust manifold, too. One injector out of six it's a big question sign on that engine. Do yourself a favor and put it on a dyno. I know it is not so cheap but anyway, it's a lot cheaper then that method I hate from the bottom of my heart : " try and error". In the end you will end up with a lot more damage on the engine, tons of money and time spent guessing what that may be.
